Twilight Trees?
Re: Twilight Trees?
So you're on a Mac, then?
Well, here's my lame attempt to make a "recursive" version of the tree (Hoping someone takes up the idea )
Re: Twilight Trees?
The trees you're mentioning are trees from Greenworks Xfrog and as long as SU is fairly poor when it comes to handle high-poly, it's impossible to import these trees directly into SU and thereby render them using Twilight Render...marvins_dad wrote:I like the way the Kerkythea trees rendered in K - but haven't found a way to bring those into SketchUp.
Is there a chance we will be getting some Twilight Trees at some point...or is there a way to bring in the trees that we could bring into Kerkythea?
(You might have luck importing one tree, but SU will be very slow...)
Having said that - and without spilling the beans - I hope that in the future you will be able to render these and similar high-poly trees and other high-poly components...
It's a matter of making an instancing system, where you place a low-poly component in SU, but when rendered it will be replaced by a high-poly component...
Cross your fingers and make a wish and maybe some day it will come true...
Re: Twilight Trees?
http://www.bbc.co.uk/worldservice/learn ... eans.shtmlFrederik wrote:without spilling the beans
I like this BBC show
Watch the rest of the videos, they're lots of fun and you'll learn a couple of things:
http://www.bbc.co.uk/worldservice/learn ... heteacher/
...sorry for the Off Topic. Perhaps we should start a thread on Resources for English learners?
Re: Twilight Trees?
Have you tried the 2.5d trees? They don't load your SU models much at all and they render nicely-to-excellent in Twilight (though some of them require the leaf-bunch image to be exploded, then the 4 image-face edges to be hidden).
You can find several free ones to play with on the SketchUcation forum.
Re: Twilight Trees?
@ecuadorian
beautiful fake tree
beautiful fake tree
Re: Twilight Trees?
Fredo has a "Ghost Component" Plugin which is very promising along with TL's ability to render components on hidden layers.
Gai...
Re: Twilight Trees?
Leaves in Twilight benefit a lot from having some translucence
- SketchUp: 8 Pro
Re: Twilight Trees?
Here they are in my model.
I'm going to have to check out the other suggestions...definitely need a big library of trees that look good.
- EastFacade-EyeRt_57 threads.jpg (347.58 KiB) Viewed 13533 times
- SketchUp: 8 Pro
Re: Twilight Trees?
Can't search for "2.5d" on their forum...so having a hard time finding the threads you are referring to.
tomsdesk wrote:Have you tried the 2.5d trees? They don't load your SU models much at all and they render nicely-to-excellent in Twilight (though some of them require the leaf-bunch image to be exploded, then the 4 image-face edges to be hidden).
Re: Twilight Trees?
Search "tomsdesk" in the components forum...(beautiful modeling on the courthouse BTW)
