overcast
overcast
Attached is an overcast image rendered with a hdri image in "hemispherical sky" and preset 8 for 5 hours.Sunlight was disabled to remove all harsh shadows and the scene was then post processed in photoshop.Im happy with the stone but I think the timber is flat and needs more work.
- Overcast 1.jpg (587.44 KiB) Viewed 12737 times
- SketchUp: SketchUp 8 free
Re: overcast
Nice render! But i.m.o. the DOF makes it feel like a scale model a bit.
Re: overcast
I think this is an awesome image, I would love to see the raw image as you have integrated the photo so seamless.
Re: overcast
where is the cat? great work, maybe too much blur in foreground but still very well integrated.
Oli
Re: overcast
thanks for the comments guys.
Solo,attached is the original image from twilight unprocessed and I have also uploaded the processed image with foreground blur removed.
I use a LOT of post processing in all my 3d images,sometimes its like the fun dosent start until the image is rendered out and I can start changing things!
- Overcast original.jpg (343.05 KiB) Viewed 12669 times
- Overcast unblurred.jpg (748.1 KiB) Viewed 12675 times
Re: overcast
lol not enough blur now......i will keep my mouth shut.
I agree about post process....can be a bit of fun and enhances renders 10 fold.
Oli
Re: overcast
Looks nice without the DOF effect. I believe if you warmed up the Twilight output a little, the two elements would mesh better.
_______________________
Phil Meadows The Succinct
Re: overcast
beautyful render! the concept overcast is good - a very common theme one should think, but seldomly chosen for renders...
I like them both, with and without DOF. Maybe the foreground plants do not match because they were shot on a sunny day?
Why not try some "overcast-manipulation" on them in PS?
xxx
xxx
Re: overcast
David, what is your method for blending the grass against the building so you do not get the harsh edges.
Is this a mask and then a brush?
Nice render.
Nice render.
Re: overcast
Hi Dylan,
I usually use the clone brush as this allows the copied image to bleed slightly against the background.You often end up with a slight blur at the edge as in this image but it helps to marry the 2 images.
