Kalwall Material
Locked
rudy970
SketchUp: 2015 Make
Kalwall Material
Post by rudy970 » Thu Mar 05, 2015 4:06 am
Hello All. Just joined and just downloaded Twilight. I am a former Kerkythea user so I think the transition should be pretty easy and I can already tell that this is 100x easier to use.
I was wondering if anyone here has tried to make a Kalwall material or object. If you are not familiar, Kalwall is a translucent wall panel that is made up of two sheets of fiberglass reinforced sheets (not 'plastic' according to the company) over a grid core. The cavity is also insulated. The lighting effect is pretty amazing. See attached. I have seen forum posts for other renderers and wanted to see if anyone has any ideas here. I figured that I would have to build up the panel just as the actual product is done and try to find a rice paper like translucent effect.
Here is the company's website:
http://www.kalwall.com/
Cheers!
Rudy
OS: Win10
SketchUp: 2016
Re: Kalwall Material
Post by Chris » Thu Mar 05, 2015 5:02 am
Post by Fletch » Thu Mar 05, 2015 11:53 am
use the translucent leaf template and set Opacity in Sketchup to 10 or 20 percent but leave default scattering at 90 percent. this should work when your model is a single face.
Post by Fletch » Tue Oct 16, 2018 1:12 pm
Download scene below.
Kalwall material
Template>Translucent>Leaf
Set to 50% and 90% as shown in screenshot.
Scene lighting : Light Emitting material on ceiling - 100w/m2
Scene render settings: Easy 09
kalwall-testscene.skp
(598.55 KiB) Downloaded 635 times
kalwall-testscene_Scene 1.jpg (162.49 KiB) Viewed 12240 times
JGA
OS: win7 pro 64 bit
SketchUp: 2015 pro
Post by JGA » Fri Oct 26, 2018 12:59 pm
Thanks for the sample model
JGA
Post by Fletch » Fri Oct 26, 2018 5:47 pm
:hat: ;)
Locked
