A place for users to put their materials for everyone to share
thomthom
Post
by thomthom » Thu Jan 27, 2011 12:46 pm
Fletch wrote:by "fail" I mean...
so sorry ThomThom! My mistake.
I was choosing "backface to frontface" and instead I should have been choosing "Front Face to Backface" - which of course works PERFECTLY.
Ah!
Btw. What tree is that you used? I'm not finding it.
- OS: PC 64bit
- SketchUp: 2016-2023
Post
by Fletch » Thu Jan 27, 2011 12:49 pm
it is
Tea - here
3ds
obj
Running Cleanup was a good idea!
Cleanup Statistics for the Tea model:
> Edges Reduced: 1320
> Edges Repaired: 0
> Faces Reduced: 660
> Purged Components: 0
> Purged Layers: 0
> Purged Materials: 0
> Purged Styles: 0
> Total Elapsed Time: 139.68
Files size was only reduced to 7.8Mb
These xfrog files are likely difficult for SketchUp to handle. But they render easily/no hassle/perfectly with Twilight.
thomthom
Post
by thomthom » Thu Jan 27, 2011 12:57 pm
My stats for a different tree:
Code: Select all
Cleanup Statistics:
> Edges Reduced: 33480
> Faces Reduced: 33452
> Purged Layers: 0
> Purged Materials: 0
> Purged Styles: 0
> Total Elapsed Time: 15.03
Model processed in 1.112s
Code: Select all
Model Statistics
SH10_2.skp
Edges 107187
Faces 48002
Triangles 81415
Everything is triangulated, including the leaves. So usually one has a lot to gain from cleanup. I recommend that you set it to ignore UVs. And disable Duplicate Faces.
thomthom on Thu Jan 27, 2011 12:58 pm, edited 1 time in total.
- OS: PC 64bit
Post
by Fletch » Thu Jan 27, 2011 12:57 pm
The reason I was avoiding the .3ds file is because when I imported the .3ds of the Sponza model a couple years ago into SketchUp is failed miserably in the material mapping.
I guess .3ds import has since been fixed in SU. I will test it.
massimo
- OS: Win 7
- SketchUp: 7.1 pro
Post
by massimo » Thu Jan 27, 2011 12:59 pm
The render I've did was made without reversing any face because the model comes with the textures applied on front faces.
massimo on Thu Jan 27, 2011 1:03 pm, edited 1 time in total.
- OS: PC 64bit
Post
by Fletch » Thu Jan 27, 2011 1:02 pm
No, they render perfectly, but in order for them to look attractive in SketchUp, the reverse face must also have the material painted onto it. This is the purpose of the UV tools exercise above.
see the difference of the appearance in SU...
massimo
- OS: Win 7
- SketchUp: 7.1 pro
Post
by massimo » Thu Jan 27, 2011 1:03 pm
Right.
Ron_Bruins
- OS: Windows 7 64bit
- SketchUp: 8.1
Post
by Ron_Bruins » Fri Jan 28, 2011 9:56 am
Shouldn't this topic be moved to materials and resources?
Regards, Ron
- OS: PC 64bit
Post
by Fletch » Fri Jan 28, 2011 10:08 am
Voila.
Gareth
- OS: Windows 10
- SketchUp: SU8 to SU2019 Pro
Post
by Gareth » Sat Jan 29, 2011 2:20 pm
some of them take forever to import in to SU.....
i am saving each of the ones i am most likely to use....here are 3 i have done so far, and if anyone wants the skippies i will be happy to post the files, it will save people having to go through the whole process
- Grevillea.jpg (55.3 KiB) Viewed 13167 times
- Japanese Walnut.jpg (36.43 KiB) Viewed 13169 times
- Sweet Birch.jpg (52.85 KiB) Viewed 13163 times
