Templates and Libraries
SectionAA
Re: Templates and Libraries
Post by SectionAA » Mon Aug 08, 2011 1:04 pm
Fletch wrote:The material texture in SU will only change if a texture exists in the material from the library which you are applying has a texture which can be inserted. In many many cases for library materials there simply is no texture to insert, and therefore it remains unchanged. This is advantageous, for instance, if you are applying the library material "Chrome" from the NK metals but you want the chrome in your scene to remain looking like that fake default shiny metal in SU. Then you have the best of both worlds.
If you replace a stone in SU with a library Stone texture it will insert the image if you right-click the library containing a texture and choose "Texture To SketchUp" in the context menu.
Thanks for taking the trouble to reply Fletch.
Of the 151 materials in the Libraries, including Lampshade II, only 4 have textures as far as I can tell (those in Architectural).
There isnt a "Stone" category in my Libraries, although there is in Templates.
Perhaps the way to use Library materials is to create a material in SU, naming it the same as the Library material, giving it a distinctive appearance that can be recognized in normal view of SU, and apply that SU material to the faces in the model. Then apply the equivalent Twilight Library material.
Thanks again.
Barrie
SectionAA
Post by SectionAA » Mon Aug 08, 2011 1:10 pm
Fletch wrote:
SectionAA wrote:However, if having first chosen one of these three, and a material different from these three is then applied, the appearance in SU does not change.The appearance from the last of those three materials applied is retained. But the new material is correctly displayed when rendered.
Seems odd, we will look into this issue. Have you tried if problem persists after right-clicking the library material containing a texture and choosing "Texture To SketchUp"?
I didnt do it that way, and yes, if it is done that way (Texture to Sketchup) the texture does change.
Thanks.
Post by Fletch » Mon Aug 08, 2011 4:22 pm
SectionAA wrote: Perhaps the way to use Library materials is to create a material in SU, naming it the same as the Library material, giving it a distinctive appearance...Then apply the equivalent Twilight Library material.
This is a very good workflow. :^:
Locked
