Render Farm Build for Twilight and Kerkythea
Re: Render Farm Build for Twilight and Kerkythea
Awesome...
I've never played with network rendering myself, but I do see the potential...
Kim Frederik
Twilight Render Support
Kim Frederik
7hours...
Bradley
Bradley
- rfarm7hrs-milddenoise.jpg (491.6 KiB) Viewed 14711 times
1 hour 45 mins - 1500px large image... very mild postpro (vibrance and VERY minimal denoise)
Bradley
Bradley
- scene4-1hr45mins-19pass-postpro.jpg (656.64 KiB) Viewed 14713 times
3 hours - 25 pass
Bradley
Bradley
- scene3-3hrs25pass-postpro.jpg (660.53 KiB) Viewed 14689 times
Scene 1 - 3 hours - 30 passes... First Image Raw, Second Post Production (denoise only)..
C&C Welcome and appreciated.
Bradley
Bradley
- Raw
- scene1-testsave3hr-30pass-server copy.JPG (470.24 KiB) Viewed 14668 times
- Denoize
- scene1-postpro.jpg (715.03 KiB) Viewed 14673 times
Another View...
C&C Welcome...
3hours render time... denoise and Post-Pro Lighting...
Thoughts?
Bradley
C&C Welcome...
Thoughts?
Bradley
- PostPro
- scene4-postproupdated.jpg (485.01 KiB) Viewed 14657 times
- Raw (originally saved as PNG - resaved as JPG, but no changes...)
- scene4-3hrs-RAW.jpg (464.76 KiB) Viewed 14649 times
As usual - Kudos, props, and many thanks to Deeerei on the space - I think we work together well
Bradley
Bradley
They look really good.
Where do we sign up to use your machine.......
Well,
I'll be getting to that soon
In the meantime, I've taken the night (literally lol) to render a relatively large/complex model (1600x2400) for your viewing pleasure.
Credits As Follows:
Greg Schwartz, materials
Scene by Greg Schwartz and Team Twilight.
Kudos on the great work guys!
So on to the Render... If you don't know the specs of this setup - just look back at the beginning of this post. A few items to note... In order to get these things to fit within the Forum/Board filesize specs, I was forced to reduce the size of the overall image to 90% and save at a PS quality setting of 9 (believe me, I jacked with this for an hour trying to find an across-the-board save that would fit all these as close as possible to the original render). Otherwise (from the images you see, I've simply overlaid the entire Image (@ 50%) and a line of text to explain the time/passes. For those interested in seeing the raw speed here - this should do it for you. There is NO "EDITING" OF THE IMAGES HERE - NO POSTPRO OTHER THAN TO RESIZE TO FIT THE FORUM. However, for the Purists, here is a link to the FULL-SIZE, UNEDITED JPGS:
http://97.77.209.118:9500/saves-Jubilee.zip
For those that are looking to see the speed - here ya go (remember, these will be a bit lossy, due to the lower-quality save to retain pixel dims as much as possible)
Credits As Follows:
- 5mins copy.jpg (623.99 KiB) Viewed 14636 times
- 1hr-6pass copy.jpg (749.21 KiB) Viewed 14635 times
- 2hr-10pass copy.jpg (686.93 KiB) Viewed 14636 times
Last edited by bradleyabbott82 on Wed Feb 29, 2012 10:41 am, edited 1 time in total.
Users browsing this forum: No registered users and 12 guests
