How to use Twilight with SketchyPhysics
Re: How to use Twilight with SketchyPhysics
Thanks for the hints. Still i'm not sure why it rendered like this, but i've done few animation renders from scratch keeping in mind everything you've said and it's fine now. And the camera movement is soo smooth. Thank you (or whoever is responsible) for implementing Sketchyphysics animation in Twilight.
And the new animation can be seen here: http://www.youtube.com/watch?v=q3Lp-fAg0oM
that. tank. is. awesome.
Great work! I hope you shared this with others at other forums you are involved with.
Can't wait to see more from you.
If you were able to send me a higher quality video to email at suppport at twilightrender we would look at putting it on the website here for you.
That's a great little animation. Thinking SU back to couple of years, it's almost unreal how it evolved thanks to 3th part developers.shareck wrote:Thanks for the hints. Still i'm not sure why it rendered like this, but i've done few animation renders from scratch keeping in mind everything you've said and it's fine now. And the camera movement is soo smooth. Thank you (or whoever is responsible) for implementing Sketchyphysics animation in Twilight.
something with less heavy compression... seems pixelated on YouTube...
I can resize it smaller if it's too high or wide.
have you tried Xvid codec compression?
The original file i uploade to youtube is actually compressed with xvid with very high quality leaving the file size acceptable but not adding any compression artefacts. but the animation was rendered at 500x260 and than i resampled it to 1000x520 (it wasn't necessary really) hence the blurred image.
ok, send original size with xvid compression, please
Hi all,
I just joined this forum and haven't had time to even try Twilight yet, but based on comments from another forum I belong to, I just bought it. I would love to see a video tutorial on the animation process. Any chance of that?
Cheers,
Jeff
Cheers,
Jeff
We will make a nice tutorial for this.
Until then, there is this one.
Twilight is the same problem that i pointed on twilight forum a while ago. What it is is the fact that when i have my scenes set up in sketchup and when i play sketchup animation the camera transitions are smooth. But when twilight renders the SP animation camera behaves weird sometime. I don't know why. I thought i figured it out already as i didn't have this problem with other SP renders but it happened again with the Stug
Defeat is not bitter unless you swallow it.
Users browsing this forum: No registered users and 39 guests
