The guy behind Artisan, Bool Tools and Profile Builder (Dale Martens) has released SketchUV. It's a UV Mapping plugin for SketchUp.
We did a review for our webmag on SketchUcation which you can read here (Issue 9)....
http://sketchucation.com/catchup/
Or if you head on over to Smustard you can checkout a few videos of it in action.
http://www.smustard.com/script/sketchuv
SketchUV plugin released
I don't drink these days as i'm allergic to alcohol.
I breakout in handcuffs!
http://richardobrien.moonfruit.com/
Re: SketchUV plugin released
Fascinating! Thanks Rich.
Bought this yesterday - just need a project to try it out on!!!
FYI: many of the exporter plugins will "explode" distorted, single images into zillions of image pieces (this is a "feature" - a sort of difference between SU UV mapping and other file formats' UV mapping) unless you triangulate the surfaces (Dale has built in a special triangulation algorithm to do this).
However Twilight Render (and also already Thea to be fair here) handle these UV maps correctly without the need of any kind of triangulation.
Gai...
