Playground
truevis
Playground
Post by truevis » Fri Sep 25, 2009 3:32 pm
I like how this came out. I couldn't figure out how to get the exposure of the sky and the scene balanced, so I mashed-up some layers in PS. It uses a sky probe for lighting.
It would be better if I could get the balance right all in one render but I don't know how. If I up the camera exposure to make the scene good, the sky is too bright -- and vice-versa.
pg2 mix.JPG (141.67 KiB) Viewed 5286 times
Ecuadorian
OS: Windows 7 Pro 64-bit
SketchUp: 7.1
Re: Playground
Post by Ecuadorian » Fri Sep 25, 2009 4:09 pm
What preset are you using? If it's any one from Easy 01 through Easy 08, you can use Tomasz Marek's "Bring My View Back" script to add a background:
http://www.tomaszmarek.eu/sketchup_1.html
...and then make it render exactly as you want:
http://twilightrender.com/phpBB3/viewto ... f=12&t=471
truevis
Re: Playground
Post by truevis » Fri Sep 25, 2009 4:26 pm
Ecuadorian wrote:What preset are you using?
Easy -08
I'm simply seeking a way to reduce the exposure of the sky probe a little. "Sky Brightness" doesn't see to affect it.
What about darkening the HDR that I use for the sky?
