Steps with LED strip lighting under handrail (stairs / stairway)
Here's my quick WIP of this image someone shared here recently. This scene took me about an hour, maybe two, from start to finish. MUST USE Twilight Render V 2.15.3 or later.
Feel free to open the attached SKP file and make your own changes/explore how lighting and everything was done.
- steps.png (491.4 KiB) Viewed 21556 times
- Original Example Image of Scene
- 063504BC-5CF3-41A3-AF73-8D7F39A3289D.jpg (157.27 KiB) Viewed 21556 times
- STEPS.skp
- saved to 2016 format
- (1.34 MiB) Downloaded 941 times
Re: Steps with LED strip lighting under handrail
when I open your scene, the render is complete dark, even when I change the backgrundsettings.
It works for me very well, when I export the model in a new file
Did you download and install the latest version of Twilight Render? My guess is that it's black because you have an older version of Twilight Render, and this is using the new ACES tone mapping algorithm.
another question to light settings.
render in preset #9:
I would like to achive the attached photo
the light of the stripes is also lightning the scene (see at the drawers) What setting should I use to get the same result in the render?
The light strip should be a little wider according to your photo example, set to 500 watts and 13 lm/w .
Try a little "bloom" to get the "glow".
skippy attached.
it needs to be balanced with the light in the scene and the post-pro settings used.
skippy attached.
- cabinets.skp
- (3.46 MiB) Downloaded 709 times
- Untitled-1.jpg (147.22 KiB) Viewed 19143 times
thank you. I've learned something new. bloom makes the diffenerce.
where can I find some documanation about the postpro settings?
- phm006.jpg (187.2 KiB) Viewed 19113 times
- phm006-bloom.jpg (205.11 KiB) Viewed 19113 times
and the result:
- phm005pp.jpg (303.85 KiB) Viewed 19110 times
- phm007pp.jpg (271.83 KiB) Viewed 19108 times
I like such a simple furniture system. The pants shelf is pulled out? I never would have thought of that. What are the profiles with the LED system here?
Users browsing this forum: No registered users and 54 guests
