realistic grass
realistic grass
a fellow MAC user recently sent me a message on how to create realistic grass and I lost it. Please re send me this information. One of the methods was to use scatter, which I have bought, but can't seem to get it to work .
Re: realistic grass
Are you having trouble setting up Skatter in your SketchUp model or when your trying to render a scene that has been successfully set up with Skatter ?
Re: realistic grass
Subject: Twilight V2 and Skatter
Chris wrote: ↑Wed Mar 18, 2020 2:41 pm I just tried 2020 and it is working there too. My first run through, it didn't render but that was because I missed a step. Here are the steps I followed:
- Create a "floor" component made from a rectangle
- Open the Skatter editor
- Open the Skatter Library
- Choose one of the grass models from the Skatter library and select "Full Geometry" and "Render Only"
- In the Skatter editor, click the Hosts - Add button and click on the floor component previously created. Note that the preview will show the grass fully populated on the floor.
- If not already checked, click and check Render Only in the Skatter editor.
- Click (re)Generate! I missed this step the first time because the preview populated right away in the last step. But you still MUST click it.
- Render (probably with Interior/Interior+)
Re: realistic grass
still can't use 3d bazaar
won't accept my password, and when I clicked on "forgot password". NOTHING HAPPENED.
- Screen Shot 2022-05-06 at 8.59.12 AM.png (392.69 KiB) Viewed 3585 times
- Screen Shot 2022-05-10 at 9.31.03 AM.png (364.5 KiB) Viewed 3585 times
- Screen Shot 2022-05-21 at 2.29.56 PM.png (83.78 KiB) Viewed 3585 times
Re: realistic grass
I see no "library" in scatter composition editor, so I assumed it was the 3d bazaar . Am I wrong? if so where is this library?
- Screen Shot 2022-05-21 at 2.46.15 PM.png (281.1 KiB) Viewed 3583 times
Re: realistic grass
library is accessed via the Library button on the Skatter toolbar. If you have questions on using Skatter, or if you need help with licensing for the Skatter product, please contact them. We do not have any affiliation/association with Skatter. We only use their product to make grass.
