Shokin Tei
Re: Shokin Tei
Thank you all, glad you like it.
Moujiik
Moujiik
Re: Shokin Tei
High praise indeed, well earned indeed.
Re: Shokin Tei
This is really brilliant. Also, I used Photomatch adjustment and matched your render with a real image.
- Desat5.1-cor.jpg (1.01 MiB) Viewed 3851 times
Re: Shokin Tei
Hi, the lighting is much better, the image seems more realistic. What is this Photomatch adjustment you've done ?
Re: Shokin Tei
looks like some sharpening and tone mapping and some warping of the image likely to match another example photo that was underlayed.
- Desat5.1-cor-combo.jpg (282 KiB) Viewed 3835 times
Re: Shokin Tei
Well done Fletch! You are absolutely right and here is the process:
I opened an image in photoshop and then matched the render with it. This is the path in PhtoShop: Image--> Adjustments --> Match color..
This did the main job
I then used Unsharpen mask and finally the lens correction filter (vignetting and red-blue shift). You may do the same job in Photopea, in the same way.
Re: Shokin Tei
You guys blow my mind. I wish I had the knowledge and skills/talent that the two of you have. You produce some really great work and are very good at sharing with the rest of us.
Re: Shokin Tei
Sorry for not describing the process clearly first. It is because it is hard to reach the forum ( Bkz of filtration) and I am somehow listless and weary lately after the tragic death of Mahsa Amini and the afterward incidents, you know.
Re: Shokin Tei
Thank you Fletch and Majid. I'll try the Photopea website, seems powerfull and simple to use.
