Courts Entry Porch
- SketchUp: 8
Re: Courts Entry Porch
Wow, with 55° it looks really better...
Cheers, Fred.
http://www.fredericmoro.com
much improved!
brick material still seems weak... which template are you using for it? do you have a special bump map applied or just linked to the SU texture? (needs something special made I think)
the ground material is tiling... could post-pro that out easily I think if you don't want to fix the texture.
anyway - this is one to be proud of... people are always tough to make convincing... unless client specifically requests them, best to leave 'em out.
skyline missing a treeline... could add in post-pro, use spherical with treeline in it, or strategically place billboard trees to look good in reflections and direct distance... an image to reflect that is of a parking lot could look good
- SketchUp: 8 Pro
The brick material is a custom map...has an accompanying bump map and I bumped it to 5.
Added sperical sky with trees. Here is what it ends up looking like with slight level tweak in PS. Oh - and I pulled it to a 70mm FOV.
- Porch-Twilight-137pass15hrs-post.jpg (323.02 KiB) Viewed 7105 times
- Porch70-skchp-post.jpg (295.05 KiB) Viewed 7105 times
- SketchUp: 8 Pro
Oh - and Fletch - thanks for all the tips!
One thing i find odd a bit that you have long and soft shadows like you would get in the morning/evening but the background is bright daylight lit.
Did you model the curtain wall? It's nicely detailed!
Cheers,
Adam
Adam
- SketchUp: 8 Pro
Busted! It is morning lighting, east facade. I used a spherical sky...which is bright. You have a very good eye!
Yes, I built the curtain wall. Part of the design of techy look for the glass and details while the rest of the building is more traditional looking in massing.
Users browsing this forum: Amazon [Bot] and 2 guests
