Sponza
Sponza
Hi All,
Here's a Twilight render of the well known Sponza model...
You can download the Sponza model >>here<< and try to render this model yourself...
Re: Sponza
Another angle...
Re: Sponza
coud use some soft shadows
Re: Sponza
I used the KT no 17 preset (Path Tracing Progressive) on this one and soft shadows are turned on...Fletch wrote:coud use some soft shadows
Re: Sponza
can you post a screenshot of sun dialog showing settings used?
Re: Sponza
Here ya go...
Re: Sponza
very strange.
would you mind if I ask you to try rendering it with those settings again? perhaps there's a bug or something...
here's what I get with your settings... I think you'll agree it's quite a bit softer shadow than yours?
(when I opened the sponza model you posted, the soft shadow box was UNCHECKED )
- sponza-SunAt50.jpg (62.67 KiB) Viewed 29717 times
- after a few more minutes...
- ppt-2.jpg (322.75 KiB) Viewed 29706 times
Re: Sponza
Hhhmmmm.... Good point, Fletch...Fletch wrote:(when I opened the sponza model you posted, the soft shadow box was UNCHECKED )
Maybe the render posted didn't have the soft shadow box ticked...
Can't remember now, cause I've played with the settings, saved the model and now when I open it, the soft shadow box is ticked...
Re: Sponza
Just bumping this thread, in case anyone else want to play a little with the Sponza model...
Re: Sponza
It's always a good test subject.
