Modern House Exterior Scene
Posted: Sat Mar 09, 2019 10:57 am
"Little Boxitecture" is a quick house model scene we created for testing. It renders extremely fast with Easy 08 render setting and twice as fast using "Fast Forward" denoise plugin for Twilight Render.
Here's a simple modern house exterior scene ready to render with Twilight to help get you started. It is saved into SU 2013 format to maximize chances for compatibility with our users.
Please note that if the bump map is not working on the house siding that the corrugated metal bump map will need to be exported and saved, by you, to a location on your hard drive, then open the corrugated metal siding material in the Twilight Material Editor and load in the bump map. It is painted onto the ground in the middle of the street for you convenience.
Get Little Boxitecture scene here.
Re: Modern House Exterior Scene
Posted: Sat Mar 09, 2019 3:55 pm
by tuna57
Very cool ! Thanks Fletch :whoot:
