Twilight V2 and Skatter
ntxdave
OS: Win 10
SketchUp: 2020Pro
Re: Twilight V2 and Skatter
Post by ntxdave » Sat Jun 03, 2023 12:04 am
Chris wrote: Thu Apr 02, 2020 4:22 pm Phil, did you check that Skatter is enabled in the Render Editor? Under Settings -> Advanced Settings there should be a checkbox for Skatter.
I can not find this. Can you be more specific where to find this setting?
Post by Fletch » Mon Jun 05, 2023 10:11 am
Please be sure you carefully follow these steps:
Subject: Twilight V2 and Skatter
Chris wrote: Wed Mar 18, 2020 2:41 pm I just tried 2020 and it is working there too. My first run through, it didn't render but that was because I missed a step. Here are the steps I followed:
  • Create a "floor" component made from a rectangle
  • Open the Skatter editor
  • Open the Skatter Library
  • Choose one of the grass models from the Skatter library and select "Full Geometry" and "Render Only"
  • In the Skatter editor, click the Hosts - Add button and click on the floor component previously created. Note that the preview will show the grass fully populated on the floor.
  • If not already checked, click and check Render Only in the Skatter editor.
  • Click (re)Generate! I missed this step the first time because the preview populated right away in the last step. But you still MUST click it.
  • Render (probably with Interior/Interior+)
ntxdave
OS: Win 10
SketchUp: 2020Pro
Post by ntxdave » Mon Jun 05, 2023 1:18 pm
Those are the steps I have been following. However, as I mentioned in the other thread I started, I have found that one of the real problems I have encountered is with the explorer renderer. It caused TR to lock up several times and I had to turn off my computer. When rendering the same scene and settings with the regular renderer it ram OK.
Post by Fletch » Mon Jun 05, 2023 3:21 pm
too many polys for Exploration Render algorithm to handle. Maybe could work if you change the render settings/method used by the exploration render to be Easy 11.
ntxdave
OS: Win 10
SketchUp: 2020Pro
Post by ntxdave » Wed Jun 28, 2023 5:45 pm
Been playing around with the Skatter trial.
Here are a couple of images:
Q-Building-3-_Scene 1.jpg (779.63 KiB) Viewed 12542 times
Foilage on Contour.jpg (376.71 KiB) Viewed 12542 times
Post by Fletch » Wed Jun 28, 2023 9:12 pm
I like the strange low-poly but somehow high poly look of that last image.
ntxdave
OS: Win 10
SketchUp: 2020Pro
Post by ntxdave » Wed Jun 28, 2023 10:18 pm
Thanks Fletch.
I am trying to decide whether to purchase Skatter. I like the way you can develop things in a “hidden” mode which allows you to still navigate in SU. I have not/never worked with terrains before so this was just part of the learning process. Since I am just a “hobbyist” I am not sure how much I would use it. Their forum does not seem to have much activity.
Any feedback/recommendations are/would be greatly appreciated. :whoot:
ntxdave
OS: Win 10
SketchUp: 2020Pro
Post by ntxdave » Thu Jun 29, 2023 6:35 pm
Continued learning. This update includes a gravel trail and a shed.
Foilage on Contou with gravel path and shed.jpg (415.25 KiB) Viewed 12528 times
ntxdave
OS: Win 10
SketchUp: 2020Pro
Post by ntxdave » Mon Jul 10, 2023 6:46 pm
Here is my latest venture:
SU Image Test_Scene 1.jpg (382.64 KiB) Viewed 12161 times
I used the image mask feature of the Skatter plugin to arrange some bushes in the shape of the SketchUp logo. I also use the infinite plane feature of TR to create the base for the image. Used the 08 Exterior Daytime and Aces settings to generate the image. My next step is to learn the best way to combine this capability with the model in my previous post so that they are blended to gether.
ntxdave
OS: Win 10
SketchUp: 2020Pro
Post by ntxdave » Tue Jul 11, 2023 6:10 pm
I finally came up with a way to include the SU logo in my AIS model.
AIS-Majid-SU Logo_Render View.jpg (490.28 KiB) Viewed 12143 times
At least I am making some progress in the learning process. :)
