probleme de texture
probleme de texture
Bonjour
Depuis un moment (2 semaines) deja j'essai de placer une texture sur une couverture d'un lit.
Il s'agit d'un projet personnel.
J'ai essayé avec thrupaint de fredo, mais je n'arrive pas (faut dire que le thrupaint est particulierement difficile a comprendre).
Soit elle se place correctement sur le dessus mais pas sur les bords ou inversement !
Quelqu'un voudrait-il m"aider ? Merci
For a while (2 weeks) I have been trying to place a texture on a bed cover.
This is a personal project.
I tried with thrupaint de fredo, but I can't (must say that the thrupaint is particularly difficult to understand).
Either it is placed correctly on the top but not on the edges or vice versa!
Would anyone like to help me? Thanks
Vous trouverez le modele et la texture ci dessous :
You will find the model and the texture below:
dossier texture et modele ICI
texture and model folder HERE
https://mega.nz/folder/ZuByHDjS#aanYVSR8_rAe25luWm-DRQ
uploadez ici le resultat ICI
upload the result here HERE
https://mega.nz/megadrop/ausmxXeesgM
Re: probleme de texture
Alvydas made this very helpful video:
Using a proxy object (a simplified place-holder object) in SketchUp to do complex texture application (aka UV Mapping) inside of SketchUp
Twilight Pro users have some extra UV mapping tools It's not a magic bullet but sometimes it can work really well.
Thanks for your advices.
I do not have Twilight Pro, only Hobby.
Fletch, that was a really interesting post.
Follow the video tutorial by Alvydas which I posted above.
A few months ago, someone here (fletch?), helped me place a texture on a bed.
He had sent me the 3D model with the texture correctly placed.
Unfortunately, my computer system crashed, I lost the 3D model with the texture correctly placed on it.
If you still have the file, could you send it to me please? thank you
- aaaaaaa.jpg (106.12 KiB) Viewed 15303 times
Do you know what filename I could search for please?
Hi Fletch,
Thanks for your fast reply,
it's been several months, maybe the name of the file contains "bed" or "lit" or "texture", I really don't remember
it's around "Mar 24, 2021"
I'm sorry, it does not exist.
thank you for taking the time to try to help me
