Weird shadows when using emitters
Posted: Wed Jun 30, 2021 8:54 pm
by Tetiana
Hi All,
I'm trying to get a picture somewhat similiar to https://www.archdaily.com/905081/xiangc ... project=no. Currently I'm quite far from it :D and I stuck with some emitter materials.
This is how my model looks like in Sketchup (please ignore light cones, they just some remaining artefacts of my experiments and they are disabled for rendering)
As a source of light I use tubes covered with emitting texture
And this is what I get after a few rounds with Interior+ and Denoiser (image is kinda blury, it looks touch better if not stored in jpeg :) )
What I do not understand though, is why I have this weird shadow zone just before the building, I'm pretty sure this is not how light should work. Is there any way to fix this? Or I'm using entirely wrong technique here?
Re: Weird shadows when using emitters
Posted: Thu Jul 01, 2021 6:02 pm
the "shadow" is not a shadow, but rather, it's the spot lights you are saying we should ignore. Those spot lights do not exist on the original building you are trying to recreate. Or--- they are specular highlights on the pavement and they are accurate reflections.
Try to directly copy how the lights would be built on the real world building, and it works much better.
Have a look at this test scene. I think the spot lights look better than the emitter. *emitter is bottom row of lights and spots are in the top 2 rows.
Posted: Thu Jul 01, 2021 6:59 pm
Here with lighter pavers with some specular. Notice in original photo of building IRL that the pavers are not reflective.
Added the cut-outs to the fins so that the glass of the curtainwall is seen beyond, more like the original design.
SketchUP scene attached for your convenience. :hat:
Tone mapping choices are critical! Note the tone mapping settings in the attached SKP file. See also tutorial below.
Subject: ACES vs Filmic : When do I use Filmic versus ACES when Tonemapping?
Posted: Thu Jul 01, 2021 7:34 pm
On closer inspection of the original design it looks like it's a pole, and the lights are shining on a curtain/sail/screen that is likely a perforated screen material. This fabric/screen material is only attached where the lighting is desired. I could be wrong, the details are not shown clearly in the photos.
Posted: Sun Jul 04, 2021 3:46 pm
by Tetiana
Thank you very much for recommendations and files attached! This is exactly what I tried to achieve :hat:
