Hotrod.
Hotrod.
While weeding the plantation, also known as the hdd and pc memory clusters, I dug out and old Hotrod to finish. Something to clear my mind and allow the subconscious to work on the small property project. I did not realise how unfinished it was and it will take a while to adjust and correct but for what it is worth, stage one. NOT A RENDER, this is a way for me to see if the surface is reasonable and the lighting works. Not sure about the headlights so there may be a change or three.
- Ford Model A Rod Headlight Test 4 9 10p 25m Ir 0 R.jpg (346.32 KiB) Viewed 3398 times
Re: Hotrod.
Cool model. Look forward to seeing where you take it ….. render wise that is…
Re: Hotrod.
Thanks mate, I'd like the real deal or perhaps Abbey Schutto's 'rod, I have to say this quietly or Bessy will hear me......
Re: Hotrod.
Cool model and render! really cool and detailed model!
Re: Hotrod.
Thanks mate, appreciated. Moving back to the medium to small model for a while.
Users browsing this forum: No registered users and 22 guests
