Hello! New Twilight user here! I'm using SketchUp for Mac.
When I render a scene, it appears bigger in the Twilight render screen. It doesn't seem to follow the SketchUp scenes that I set. My SketchUp scene has the Two point Perspective turned on and I also use a safe frame extension.
Anyone encountered the same problem before? Please help. Thank you!
Twilight won't render exact scene that's set in SketchUp
Re: Twilight won't render exact scene that's set in SketchUp
Be sure that "Fit to view proportions" is enabled.
I don't know about that plugin, it could conflict with Twilight.
You should use the Scene View Tool on the Twilight Render toolbar to see what will be rendered.
If you pan the view after you set 2-point perspective, it will not render the panned view in Twilight. If you set your view, then set 2-point, then update your scene tab, but leave it un-panned, then it will render correctly.
- fit-to-proportionsjpg.jpg (54.11 KiB) Viewed 2216 times
Users browsing this forum: Ahrefs [Bot] and 53 guests
