dark twilight rendering
skip
Post by skip » Thu Apr 28, 2022 1:46 am
why is my rendering so dark?
Screen Shot 2022-04-27 at 8.41.17 PM.jpeg (117.94 KiB) Viewed 5217 times
Re: dark twilight rendering
Post by Fletch » Thu Apr 28, 2022 12:54 pm
Did you disable the sun?
Open Twilight Environment Editor and enable the sun.
skip
Post by skip » Thu Apr 28, 2022 6:59 pm
no I did not.
Post by Chris » Thu Apr 28, 2022 7:43 pm
It's hard to tell based on the screenshot.
What kind of sky environment are you using? Looking at the reflection in the wall, it looks like physical sky. What time of day is your SketchUp scene set to? It looks like you have a backdrop (the trees and whatnot); is that blocking the sun? If you turn on Shadows in your SketchUp scene, what does it look like?
skip
Post by skip » Fri Apr 29, 2022 7:21 am
Screen Shot 2022-04-29 at 2.20.16 AM.png (2 MiB) Viewed 5176 times
Post by Chris » Fri Apr 29, 2022 11:58 am
Time of day looks fine. That's the only thing we can determine from the screenshot you posted. Still can't tell if your backdrop is shadowing your entire scene or what your render environment settings are. If you share the scene we can much more easily determine what the issue is.
Post by Fletch » Fri Apr 29, 2022 1:37 pm
Please share a link to the scene so we can diagnose the problem.
My guess is that you have placed objects in the scene that are blocking the sun.
You didn't share a screenshot of the Twilight Environment Dialog, only the SketchUp sun settings.
Did you follow the video?
skip
Post by skip » Mon May 02, 2022 4:54 pm
the culprit for my dark rendering was this background. took it out and no more dark rendering. I will have to research
Screen Shot 2022-05-02 at 11.52.03 AM.png (1.08 MiB) Viewed 5091 times
different backgrounds.
Post by Fletch » Mon May 02, 2022 7:06 pm
Use a treeline spherical sky instead of physical object in the scene.
Please watch the video linked above.
