Hello,
Does Twilight work with GPU now? better still does it support multiple GPU's?
Twilight seems to be the only stable render engine that works with Animator, and I need to run animated renders and GPU renders would be fastest for such a task.
newb question
Re: newb question
Twilight Render renders on CPU, but using Fastforward AI denoise add-on for Twilight Pro uses GPU if it is an NVIDIA cuda-enabled graphics card.
Fastforward is shockingly good, and increases rendering speed exponentially. See below, each rendered 2 minutes unbiased render setting for Twilight Render. (Easy 09, Metropolis Light Transport)
It is suggested for rendering animations that you use a very high-powered CPU. AMD Ryzen Threadrippers with 64 threads or better.
- Easy09 2 mins.jpg (1.79 MiB) Viewed 2086 times
- Easy09 2 mins with denoise.jpg (888.84 KiB) Viewed 2086 times
