Hello all renderers!
I've had an issue with my renderings of water for a specific model (see attached picture). I have tried to adjust and change different settings but without luck. My concern is the shadow ring along the perimeter where water meets the bubble shaped dome, it's very unrealistic and I would rather get rid of it.
Hopefully someone can help me.
Thanks in advance!
Need help with solving a glitch when rendering water
- View 1.jpg (992.21 KiB) Viewed 1638 times
Re: Need help with solving a glitch when rendering water
choose water material with Twilight Material editor and disable "cast shadows" and render with Easy 08 render setting.
Easy 09 or 10 are fully unbiased and will ignore the cast shadows setting.
Easy 08 is for outdoor rendering with unbiased quality but will allow not casting shadows for objects and allows fake emitters.
Get a great bump texture for you pool water here:
Pool Water Bump Material Texture
Other important past pool threads:
Subject: Barcelona Pavillion
Subject: Re: Pool at night
Subject: Swimming Pool Ready4Twilight
Subject: Procedural Waters (28) for Twilight by Majid
Subject: Pool - Quick Rendering with "fake" Caustics
you can use this water.
It's the template "Liquid>Water" with a procedural in the bump and color white.
Advanced>Cast Shadow is disabled.
see attached .skp scene
Rendered on Easy 08
Rendered on Easy 08
- Pool-Big-Circle-Hill.skp
- (2.43 MiB) Downloaded 96 times
- pool-water-circle-hill.jpg (475.13 KiB) Viewed 1627 times
Is twlPerlin Tecture part of TR?
