eggs... actly and a spoonful
eggs and spoons
- Eggsactly-Wooden-Spoon-TWL_Scene 12.jpg (1.17 MiB) Viewed 6324 times
Re: eggs... actly and a spoonful
lighting and tone mapping are so essential.
Used "Unsharp Mask" 'Strength' of 2 'Threshold' of .01 to sharpen the textures/rendering.
Scene attached for your convenience. This scene lit with 2 light emitters carefully sized, power carefully set, tone mapping carefully set.
Attached is the .jpg for the surface, as the .skp file was too large to share here with the image attached within SketchUp.
You will need to load that .jpg into the table surface material yourself.
- 4 passes with Fastforward Denoise enabled.jpg (582.54 KiB) Viewed 6316 times
- Egg-Wooden-Spoon-TWL.skp
- (4.86 MiB) Downloaded 396 times
- 6872533_metalbare0234_1_seamless_m.jpg (1.39 MiB) Viewed 6316 times
changed spoon model
updated texture and UV mapping
changed to flat material template
- Eggsactly-Wooden-Spoon-TWL_Scene 13b.jpg (1.18 MiB) Viewed 6209 times
