Page 2 of 2
Re: Shokin Tei
Posted: Thu Mar 16, 2023 5:31 pm
by moujiik
Thank you all, glad you like it.
Moujiik
Re: Shokin Tei
Posted: Thu Mar 16, 2023 10:21 pm
by Mike1158
High praise indeed, well earned indeed.
Re: Shokin Tei
Posted: Tue Mar 28, 2023 6:51 am
by majid
This is really brilliant. Also, I used Photomatch adjustment and matched your render with a real image.
Re: Shokin Tei
Posted: Tue Mar 28, 2023 5:24 pm
by moujiik
Hi, the lighting is much better, the image seems more realistic. What is this Photomatch adjustment you've done ?
Re: Shokin Tei
Posted: Wed Mar 29, 2023 8:49 am
looks like some sharpening and tone mapping and some warping of the image likely to match another example photo that was underlayed.
Re: Shokin Tei
Posted: Wed Mar 29, 2023 2:13 pm
by majid
Well done Fletch! You are absolutely right and here is the process:
I opened an image in photoshop and then matched the render with it. This is the path in PhtoShop: Image--> Adjustments --> Match color..
This did the main job
I then used Unsharpen mask and finally the lens correction filter (vignetting and red-blue shift). You may do the same job in Photopea, in the same way.
Re: Shokin Tei
Posted: Wed Mar 29, 2023 2:34 pm
by ntxdave
Re: Shokin Tei
Posted: Wed Mar 29, 2023 3:05 pm
by majid
Sorry for not describing the process clearly first. It is because it is hard to reach the forum ( Bkz of filtration) and I am somehow listless and weary lately after the tragic death of Mahsa Amini and the afterward incidents, you know.
Re: Shokin Tei
Posted: Thu Mar 30, 2023 7:27 pm
by moujiik
Thank you Fletch and Majid. I'll try the Photopea website, seems powerfull and simple to use.
