Alphabet inspired sketches
Re: Alphabet inspired sketches
To place the windows on a cylinder, there are several approaches:
1- adding enough segments to the base circle, then making the hidden lines visible and placing windows (as components) on each face
2 - using joint-push-pull plugin....
3- using bend plugin to place windows on curved cylinder...
Also,,
If I were you, I would definitely gather some reference images to help my dreams come to reality...
Also,,
Thanks Majid, I will look at these again. I like both #1 & #2 the best.majid wrote: ↑Mon May 22, 2023 9:24 pm To place the windows on a cylinder, there are several approaches:
Yes, I am doing that. Also considering creating my own background. Want to get the model done first though.
Well, here is my latest work. The letter Q was the "inspiration" for this sketch and render.
The windows did not turn out exactly as I had hoped. The reflection seem not to appear in all of them.Re: Alphabet inspired sketches
Well done! The result is great...
I hope you and others find the book, inspiring and consider it as a source of creativity and pondering the shapes, then broaden this point of view to other shapes too..
Thanks Majid - I appreciate your response.
Yes, your book inspired this sketch & render and you have me thinking about some others for the future. I would like to see some others produce some sketches & renders as well.
Well here are 3 scenes but I am not happy with the results. Tried to lean how to use Skatter but had some problems.
The environment (Sky and tres) is fine except for the "invisible" ground.
I personally use 2d realistic face-me components, as my laptop is rather old.
I am working on learning how to use the Skatter plugin which “should” help.
Does it provide a slight difference in the scale and rotation of components?
I tried to go after your model and texture all day long and here is my latest try.
- untitled.jpg (118.44 KiB) Viewed 5599 times
Users browsing this forum: Bing [Bot] and 4 guests
