Need help to create materials/textures
I need some advice, or a source, for creating materials/textures that I can use in my models and renders that look like the examples in the images below without having to have hundreds of faces in my SU model. Notice that I will need to be able to have both the "face on" and side view materials/textures because they will be used from multiple angles.
Re: Need help to create materials/textures
Really need some feedback……..
Re:Need help to create materials/textures
Has anyone ever used PixPlant to create materials/textures? If so, would it be good for what I am wanting to create?
honestly that's not a texture, if realism is important to you, that's a model problem. And SU can't model that - you need Blender - which has fur and hair.
but you could possibly make a blurry spinning look texture if you want it to look like it's moving.
Thanks Fletch…..
I am exploring PixPlant. I am a little optimistic that there might be a possibility for a couple of the brushes but not all of them (the red one and the red and black one). I have modeled the blue ones before but the number of faces is very high.
I will have to explore Blender but I have not used it very much.
Here's my version, it's not photo-realistic, but would look good in the SU model.
- Brush-Spinning-Carwash.skp
- (251.63 KiB) Downloaded 233 times
- Brush-Spinning-Front.jpg (16.13 KiB) Viewed 6352 times
- Brush-Spinning-Front.png (27.58 KiB) Viewed 6352 times
- Brush-Spinning-Side.png (25.27 KiB) Viewed 6352 times
Thanks again Fletch…….yes, your textures can probably be used.
I am going to continue exploring PixPlant as it looks like it might be a good tool for developing materials/textures. Suggest you might give it a look as well. You are much better at this stuff than I am. If I do come up with something that I think is worth sharing, I will post it in this thread.
forgot to add the example render
- carwash.jpg (137.18 KiB) Viewed 6337 times
OK, what did you use to create the brush? That is exactly what I am wanting (there is sometimes a cylinder inside the brush).
There is also a version that is solid red.
I should have also asked how you created the textures in your previous post?
I attached the .skp file above, I attached the materials above.
I just took the photo you shared in the o.p. and used the warp tool in photoshop to straighten them out and then used motion blur up-down for the front of the cylinder and then made it seamless (discussed in other threads on this forum and many places on youtube)
and for the side view I took the side view of the brush you shared above and made it a perfect circle and used motion blur>radial blur in photoshop to spin it around.
