Massimo (member of this forum) posted a great scene he created in SketchUp.
You may download a version of it here ready to render:
How this scene renders on Easy 10 Interior + setting.
Original Rendering by Massimo:
OK, remember when rendering Gemstones:
We highly suggest to use the gemstone material library.
Lighting setup is key.
You can use the HDRI included with the SketchUp format scene above. It is a very low res version copy of the original.
If you wish to have the original, get it here: Dining room of the Ennis-Brown House
Also, try some of these great free HDR photography studios.
PS - if you want try his scene, with his materials, then you must use the attached material library created from his original Kerkythea scene with materials set up. Just unzip this to your Twilight/Materials folder... your folder structure should look like this EXACTLY:
See also original discussion about this topic here.
See also original post with tutorial from Massimo about this scene on Kerkythea forum.
Gemstone Jewel Diamond Wine Glass and Spoon by Massimo
- UncompromisingBlackByMassimo.zip
- MATERIAL PACK TO ACCOMPANY MASSIMO'S DIAMOND AND SPOON SCENE
- (36.2 KiB) Downloaded 1232 times
Re: Gemstone Jewel Diamond Wine Glass and Spoon by Massimo
Final render, rotated sky to be back at angle "0" (zero) and rotated the camera just slightly, both in order to get rid of glare off of the diamonds.
Black backdrop could still be improved to change ground reflection from gray to black.
- UncompromisingBlackByMassimo-Easy10.jpg (169.9 KiB) Viewed 17388 times
