This animation, made to demonstrate to potential customers of this client the ease of installation for a digital screen mounting device, was rendered with Easy08 render setting, without sun, but sky set to white.
The Easy08 Animation 100 setting was modified to be only 30 iterations by opening the .xml file for the render setting, changing the number of iterations to "30" instead of "100", then saving the .xml file with a new name into the Animation settings folder. It was rendered, saving the .jpg sequence to a folder.
Virtual Dub was used to encode the file to H.264 format using the tip Subject: Animation sequence to H.264/MP4 video from Ecuadorian.
The original .avi resulting file is only a little over 1Mb. However, after uploading to Youtube, it has degraded the quality significantly.
See clean/clear .avi here.
Animation with Unbiased Rendering (Easy08)
