Stained Glass Window
d12dozr
OS: Windows 8
SketchUp: 8 Pro
Post by d12dozr » Sat Aug 29, 2009 5:54 am
Hi everyone, my first post here :) I just downloaded the trial version and am trying a little test.
A couple months ago there was a Stained Glass Challenge over in the Sketchucation forums: http://forums.sketchucation.com/viewtop ... +challenge
I am trying to re-render my Sketchucation entry using Twilight, and am very satisfied with the way the window itself came out, but I'm not getting the effect of the sunlight on the wall I'm looking for...I just need a little help, I'm sure. There are nice bright colors from the sunlight on the sill, but they fade away before reaching the wall - well they are there on the wall, but very, very faint.
I used architectural glass-common, generic-soft on the walls, and sunlight intensity of 100. I used easy preset #9 for about 30 mins.
I'm trying to make it look something like the second picture(rendered with a different software):
stainedglass twilighttest.jpg (257.04 KiB) Viewed 16853 times
Stained Glass-IRender.jpg (32.43 KiB) Viewed 16849 times
-Marcus
Re: Stained Glass Window
Post by Fletch » Sat Aug 29, 2009 11:29 am
Hi d12dozr, Welcome :D
The colored light shining on the wall thru the window is called a "Caustic". This word refers also to shiny spots that bounce off of shiny surfaces, or refract through surfaces, like the glass sphere in the Intermediate Video Tutorial for instance.
Easy09 will not produce caustics from the Physical Sun and Sky. If you use a light emitting surface behind the window, then you will see caustics with 09
Easy10 will ultimately be easiest/best, as it produces caustics with any light source, but renders most slowly.
Easy02-07 will produce caustics with most light sources, and be quite quick to render... the higher the setting, the higher the quality.
Post by Fletch » Sun Aug 30, 2009 6:35 am
d12dozr,
Please see attached example.
Twilight_StainedGlassWindow.zip
(738.62 KiB) Downloaded 813 times
Single Pane Glass version rendered on Easy02-low setting in 15s
Double Pane Glass version looks nicer, in my opinion, rendered on Easy02-low setting in 23s
d12dozr
OS: Windows 8
SketchUp: 8 Pro
Post by d12dozr » Mon Aug 31, 2009 2:26 am
Thanks Fletch,
I tried "Realistic Glass" with double panes on my model using Preset #10 and now no light is getting through at all! :( I also downloaded your model and am dissecting it to see what settings you have used...hopefully I can figure it out from that. :) BTW, the edge settings are really great, especially the option for lineweight. If you want, i can upload my model for you to test...
Thanks again,
Marcus
-Marcus
Post by Fletch » Mon Aug 31, 2009 8:10 am
when using "realistic glass" on the "Thick" window, render with Tech Photon Map setting #9 or 10 It will render in about 4minutes, but it does render quite nicely.
Dylan
OS: OSX
SketchUp: 8
Post by Dylan » Mon Aug 31, 2009 8:33 am
Glad you posted that image above Fletch, I had no idea those settings were available, I had not looked in the Tech settings!
They don't mean much to me, but at least I know they are there! :)
Post by Fletch » Mon Aug 31, 2009 9:26 am
They are there for the convenience of Kerkythea users who purchase Twilight. Now they don't have to ask "Where is the old Kerkythea setting called..." ;)
Post by Fletch » Fri Jul 02, 2010 2:57 pm
Update: It is no longer necessary to use the Tech settings... you can render on any setting from Easy 2-7 and see the Stained Glass caustics with physical Sun and Sky.
If you render with Easy 09, you must use a plane in SketchUp that is painted with a Light Emitter material outside of the window shining in.
derei
OS: WIN7 Pro x64
SketchUp: 2015 x64
Post by derei » Fri Oct 07, 2011 12:31 pm
Please guide me on making a Stained Glass material for Twilight Render, all my tries failed :( I end up with a very bright window, but no light in the room, or nice caustics. I want to render it with progressive (I know that for Easy9 I have to use LEM instead of Sun).
I tried using realistic glass and applied the texture (glass with thickness, but only one face textured, the other was clear realistic glass), also I tried with single face Architectural Glass material, but it looks I am doing something wrong.
If I don't ask to much, please tell me how to make that material, It doesn't need to have solid mullions, they can be transparent as well.
Thank you.
ARTIST AND DESIGNER DEREI.UK
Post by Fletch » Fri Oct 07, 2011 10:19 pm
Did you read this thread? The scene is provided. :?
Subject: Stained Glass Window
Fletch wrote:Please see attached example.
Fletch wrote:It is no longer necessary to use the Tech settings... you can render on any setting from Easy 2-7 and see the Stained Glass caustics with physical Sun and Sky.
Users browsing this forum: Amazon [Bot] and 2 guests
