After some tweaking and modeling I was able to get this one up to a level where I felt comfortable rendering it.
If you are an SCF member you might remember this from a couple years ago.
The material setup was easy, thanks. Lighting is getting easy to understand and the background, again thanks.
I am getting some burning on the right of the image and I don't know why. Under the Fascia at the top right and under the lip of the balcony on the right.
This image could do with some line overlay so I will try the TR line rendering next.
Any other tips for improvement?
Edit: I rendered at 2000 pix wide on Low (I think). It took 20 Min.
House Rendering
- SketchUp: 2014
- SketchUp: 2014
Re: House Rendering
Thank you Tom.
I started another couple using the edge lines and got some odd results. When just checking the "Use Edge Lines" it seems to show all lines, hidden and not. When checking "Weld Vertices" it seems as if TR is smoothing the geometry. Here is the top on a "Prelim" pass.
Here is the rendering in the first post with a line overlay done the "old fashioned" way, with Photoshop using the Multiply layer filter and set at about 15% opacity.
- J15.jpg (405.85 KiB) Viewed 10183 times
- SketchUp: 2014
Re: House Rendering
Here is the same scene again with some lighting tweaks. I managed to get the light leaking to go away on the right but there is a blue leak mid image on the bottom, next to the pilaster.
Here is the same, cleaned up the light leak and added a line overlay again.
- SketchUp: 8
Re: House Rendering
Amazing images, congratulation.
Cheers, Fred.
http://www.fredericmoro.com
Re: House Rendering
Hi Boofredlay,Boofredlay wrote: I am getting some burning on the right of the image and I don't know why.
If you use low settings, and get this high of quality with only one sparkle, I'd say you should be very happy indeed!
there you go.Boofredlay wrote: Edit: I rendered at 2000 pix wide on Low (I think). It took 20 Min.
I am putting a tutorial together for Edge Lines. They are sensitive with curving geometry. If you are using "weld" you will want to use that with a specially named material in SketchUp you set up for only curved surfaces, and use a differently named material for rectilinear geometry. Hope you understand what I'm trying to say here?
I am loving the direction of this image, it's impressive! Twilight - the time of day, not the program - are a difficult choice for a time of day to render - and also with most chance of dramatic image, imho... and you are getting a very good image here.
for "tips"... I would make the sky darker ("Twilight Light Editor Dialog>Sun/Sky Tab>Sky Brightness"), and use warmer lights.
- SketchUp: 2014
Re: House Rendering
I understand perfectly. I look forward to the tutorial.Fletch wrote:I am putting a tutorial together for Edge Lines. They are sensitive with curving geometry. If you are using "weld" you will want to use that with a specially named material in SketchUp you set up for only curved surfaces, and use a differently named material for rectilinear geometry. Hope you understand what I'm trying to say here?
Thanks.Fletch wrote:for "tips"... I would make the sky darker ("Twilight Light Editor Dialog>Sun/Sky Tab>Sky Brightness"), and use warmer lights.
Users browsing this forum: Bing [Bot] and 4 guests
