Animated Water Fountain
Post by Fletch » Mon Jul 04, 2011 10:05 pm
Here's a SketchUp model of a fountain that someone created with water flowing down.
Using the Realistic Glass>Water Twilight Material Template, using the texture to drive only the bump as described in this Water Fast tutorial, one is able to render animated water from SketchUp. The animated .gif looses some quality from the rendering, but still shows the effect quite well.
Before rendering this animation, try installing these Animation Render Settings - Supplemental first. This animation was rendered with the Medium render setting with tracing depth set to 2.
Fountain-Anim02-h264.zip
h.264 format video
(71.69 KiB) Downloaded 1219 times
AnimatedFountain-TwilightRenderReady.skp
su7/8 compatible sketchup file
(264.14 KiB) Downloaded 1227 times
Pilou
Re: Animated Water Fountain
Post by Pilou » Thu Sep 15, 2011 10:32 pm
Hypnotic refreshing thing :D
Pilou (Frenchy)
Is beautiful that please without concept!
Speedy Galerie
