How can i make a chandelier look authentic?
- SketchUp: 6.0
I want to model and render a chandelier. When i use lightest glass material on each crystals, it requires lots of calculations to be done after light is set on behind them.
Do you have any idea?
I attached a render as an example(this is not done by me)
- kri.jpg (31.46 KiB) Viewed 13947 times
Re: How can i make a chandelier look authentic?
If it doesn't need to bee seen from close range, you could try with some cylinders of different height, then map with a image that mimics the glass elements, maybe use some bump ?
- chandelier-suggestion.jpg (176.49 KiB) Viewed 13929 times
ARTIST AND DESIGNER DEREI.UK
I would model it correctly, use the realistic glass template, and light with light emitter material on a circular face with 8 segments (as opposed to one with 50 segments, as each segment counts as a light).
Then I would render this either with Unbiased Easy 09, or with a custom biased render setting. If using biased render settings, the lighting would have to be creatively done.
It's possible to create a perfect crystal material like this using Kerkythea's material editor. Then it can either be set as a fake emitter, for very fast calculation in biased render settings, or as a normal emitter for unbiased.
Try this crystal material, and if you are rendering unbiased, you are done. If you are using biased, you will want to create a similar mat. library but make sure it's a fake emitter, or render times will = forever.
see detailed explanation
- 3dcrystalchandelier.jpg (127.97 KiB) Viewed 13829 times
- SketchUp: 6.0
thanks for explanation. i cant download material from its page. actually what i download can not be extracted from its archive.
I just downloaded, and it extracted fine.
Delete the ".mat" from the name before extracting if you wish to copy the folder into Twilight.
Or to install to Kerkythea, leave the ".mat" in the name. Go to File>Install library
- SketchUp: 6.0
I think i figured it out. I tweaked xml file of crystal material which was given as a link above. reduced its power to 5, changed IOR value. and i rendered in progressive mode for 90 passes. i usually use 90 passes for interrior scenes i try.
there are 9 small bulbs inside.
here is result.
here is result.
- chan.jpg (43.08 KiB) Viewed 13681 times
Wonderful result ! Can't wait to see the final chandelier rendered !
Looking incredibly realistic! That material looks great, and it will add a lot of render time due to all that's going on with it (emitting light depending on viewing angle, refracting, caustics, etc.)
- SketchUp: 6.0
thanks.
it will be better with a better design actually. even shapes of crystals i use changes the result. default light amount of material is simply too much for my needs so i adjusted it to power of 5 instead of 50 in XML file.also refraction of warm glow glass to 1.38. i can add that file later.
this is progressive type rendering in my customs settings. there are no caustics in this setting and i think i managed to optimize it by "cropping" it.
resolution was HDR 500x500px it took approx 1 hour to calculate empty room on my 8 core AMD processor.
