Showroom Layout
Showroom Layout
Hey everyone
Here is a render for the proposal of our new showroom.
I have been experimenting with Fletch's light colours to hopefully warm up my images.
Model 150Mb
Faces 260,000
Edges 560,000
Materials 131
Easy 9 for 6 Hours 100 passes 1200px
Sunlight
rgb(236, 223, 196)
Spot and point lights, can light emitter
rgb(220, 180, 120)
Cove light emitter
rgb(230, 215, 170)
Line overlay @ 20%, Neat Images DeNoise, Sharpened + Blur Overlay & Super Novas in Gimp
Hope you like it
Model 150Mb
Faces 260,000
Edges 560,000
Materials 131
Sunlight
rgb(236, 223, 196)
rgb(220, 180, 120)
Cove light emitter
rgb(230, 215, 170)
Hope you like it
- SHOWROOM_1_Adjusted_Filtered.jpg (508.97 KiB) Viewed 10999 times
Re: Showroom Layout
I think it's definitely warmer than before.
Perhaps the most difficult part is to try to balance exposure of image, intensity of sunlight, power of light emitter surfaces, spots and points.
The lights look blown out in this version. But the general illumination/exposure of the space seems good. So perhaps you can back off the power of the spots/points/emitters, but maybe only slightly back off on the sun power.
- realkitchen-overlay.jpg (147.58 KiB) Viewed 10995 times
Re: Showroom Layout
Thanks Fletch.
It's not a million miles away from the image you've set over mine. Yes the lights are blown. I must get in the habit of doing a test in Prelim. I tend to run for 15-20 mins in Easy 9 to gauge things but it always brightens up quite considerably after 100 passes.
It's funny... I've designed the island in the showroom to be a mini version of the photo you've set over the top.
Re: Showroom Layout
Here is another view. I've reduced the light intensity Bit of PP to pop the image and added line overlay and SupaNovas
It's very difficult to get it 100% right. I use 3 screens and this image looks totally different on each screen due to the colour config!
- SHOWROOM_2_Adjusted_Filtered.jpg (591.32 KiB) Viewed 10913 times
Re: Showroom Layout
Hi Dan,
Its a nice job, however, the down lights on the top of the Island should not reflect any light on the cieling (looks fake)
Re: Showroom Layout
Thanks George.
The lights over the island are open topped lamp shades so they would actually beam light up and down.
Re: Showroom Layout
not liking the clock... or the white grout lines... none of which have to do with the space or the rendering.
Re: Showroom Layout
And another view
- SHOWROOM_3_Adjusted_Filtered.jpg (603.66 KiB) Viewed 10858 times
Re: Showroom Layout
beautiful.
- SketchUp: 2014 + 2015 Pro
Re: Showroom Layout
Somehow I missed the last render, this is gorgeous! I remember your first renderings, you became a master. I believe you have some problem with the UV mapping of the Eames chair back.
I just could not help to pop it up a little in PP
- SHOWROOM_3_Adjusted_Filtered_filtered.jpg (409.27 KiB) Viewed 10217 times
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 4 guests
