cabinet door gaps
millwork
cabinet door gaps
Post by millwork » Sun May 11, 2014 9:03 pm
Hello
I've modelled a kitchen and have set the cabinet doors to have 3mm gaps between them. When I render the scene the door gaps don't show - you can't tell where the individual doors are it just looks like 1 large panel. I've tried using wider gaps like 6mm and 9mm with limited success. Is there a setting or trick that will work? I appreciate any help or responses I get.
Thank you
Re: cabinet door gaps
Post by Fletch » Sun May 11, 2014 9:21 pm
Tick the "Edge Lines" in the material you are using for the door, then set width for the line, scale is in meters, then set the smooth radius to 45 or 60... See "Edge Lines" in the User Manual. Try it on a quick test cube scene before moving on to the big model, so you can adjust your material with very quick little test renders.
Subject: Workaround for lines not showing
Fletch wrote:...this is one of the many things we made easy with Twilight.
Twilight User Manual wrote:.1= .1 meters = approximately 4” use this for large exteriors such as large buildings or interiors of very large spaces.
.01= .4” use this for fine lines around smaller buildings such as a house and elements like stairways
.001= .04” Use this for fine lines around detailed elements such as furniture objects and cabinetry.
millwork
Post by millwork » Sun May 11, 2014 9:43 pm
Hi Fletch
Thank you for your quick response. I've now tried various settings and I can see this is going to work.
Thanks again, I really appreciate your help
millwork
Post by millwork » Sun May 11, 2014 11:10 pm
Where do I find the "smooth radius" settings? I've looked in the online manual and I can't seem to find it?
Post by Fletch » Mon May 12, 2014 10:41 am
terribly sorry, it's called "Hard Edge Angle" just type in "30" instead of default "0"
millwork
Post by millwork » Mon May 12, 2014 5:49 pm
Thanks Fletch I've got it now. I've been experimenting with the values you suggested and it's working great.
