V2 OSX Render problem
Hi I actualy use Twilight 1 for MAC with SketchUp 2014
And I try to use and install vers. 2 in DEMO and have no problem with and uninstall Twilight Render Version 1. To do so, browse to the SketchUp plugins folder and delete the twilight.rb and Twilight folder. like you said in instructions.
Now i uninstall vers. 1 and install vers. 2 but can not use it. and have no one in use. I´d like to upgrade vers. 2 but I have this problem.
Thanks a lot
Rodolfo Prieto
Thanks a lot
Rodolfo Prieto
- screen-capture.png (268.63 KiB) Viewed 11216 times
Re: Twilight Render V2 OSX Install Report
What exactly is the problem? It looks like you have Twilight Render V2 installed and working... the log report shows a render being done.
before you render, choose a render preset from Twilight V2 dialog.
before you render, go to Environment Editor and load a valid sky image. The one which was used in previous scene is missing or moved to different location.
Thanks a lot, Chris and Fletch
Hello, I will explain what I did:
I install Twlight 2, then I uninstall vers. 1 and I run Twilight software 2 and have this: Photo 1
But today when I restart my computer and run SketchUp, and I made this: Photo 2
I Try to render a simple Square Walls, but only Apper the Sky: Photo 3
- But today when I restart my computer and run SketchUp, and I made this:
- 1.png (268.63 KiB) Viewed 11177 times
- 2. Then
- 2.png (449.78 KiB) Viewed 11177 times
- and the building does not only appear the sky
- 5.png (665.56 KiB) Viewed 11177 times
Check the Layers drop down in the Render window (The one to the right of camera). Make sure all your layers are enabled for rendering.
Have you tried creating a rendering a model from scratch, instead of converting an old model?
If a new model works, but the old one doesn't, PM me with the old model and I'll take a look at it (the old model *before* it's converted, if you have it).
Thanks Chris
I Try
R. I have the same problem.
R. YES I can do it, I do with a SketchUp template
if a new model works, but the old one doesn't, PM me with the old model and I'll take a look at it (the old model *before* it's converted, if you have it).
R. OK This is the example model but no one of MY personal Template is working.
Thanks, thanks a lot Chris
Rodolfo
I Try
Rodolfo
- I do with a SketchUp template
- 1.jpg (43.28 KiB) Viewed 11171 times
- 260_A1_12gh.skp.zip
- (458.96 KiB) Downloaded 508 times
Re: V2 OSX Render problem
You have a huge number of section planes in your model.
Twilight Render V2 will render all visible section planes. Unfortunately, if you have Section Planes turned off in the View menu, the planes are still "visible". SketchUp doesn't provide a method to tell TWL that the view menu has Section Planes disabled.
You will need to hide each section plane (right click -> hide) or delete each section plane.
Place section planes on layers and turn off visibilty of layers to control their visibility in Twilight Render. This is covered neatly and in depth in our video tutorial on this precise subject in the video tutorials in my signature.
Chris Thanks. I do it, and have not problem....
Thanks a lot
Rodolfo Prieto
Thanks a lot
Rodolfo Prieto
