M1 to V2 Update
Re: M1 to V2 Update
Attached is the Error Message I receive and the V1 Rendering and V2 rendering of the same scene. The file path for the materials is: C:/Program Data/Twilight/Materials. I can't send the materials library because it's too big even zipped.
- Error Message
- FullSizeRender.jpg (139.1 KiB) Viewed 9803 times
- V2 Rendering
- V2 Rendering 2.jpg (242.04 KiB) Viewed 9803 times
- V1 Rendering
- 6-10-14 Rendering.jpg (265.46 KiB) Viewed 9803 times
Re: M1 to V2 Update
I'll check the Lampshade_FastFake library and see if there are problems with it. (I assume you downloaded it from this forum?)
Re: M1 to V2 Update
It looks like there is a problem with the library. We'll figure out what's going on and get it fixed.
Re: M1 to V2 Update
There is a bug in how the libraries are being searched for. We will fix it in the next release.
In the meantime, you can fix it by going to C:\Program Files(x86)\Twilight Render 2\Legacy. Open the 'Architectural_Twilight' folder and copy all the folders in it, and paste them up one directory, in the Legacy folder. That should work for the converter to find the libraries until we get the fix released.
Thanks for bringing this to our attention.
Re: M1 to V2 Update
I have downloaded your M2 update but, I'm still getting error messages on "unable to load some materials. See the attached message.
- Error Message
- FullSizeRender.jpg (125.75 KiB) Viewed 9787 times
Re: M1 to V2 Update
Please post the material library that those materials are using.
Re: M1 to V2 Update
Attached is the material library affected. When I pull the materials up on Material Selection under Template Materials, they appear in red. When I click on the the material, it ask me "Do I want to replace the existing deep material with a template".
- Material Library
- FullSizeRender.jpg (94.46 KiB) Viewed 9780 times
Re: M1 to V2 Update
Not a screen shot. Please zip and post the actual material library causing the problem.
Users browsing this forum: Bing [Bot] and 2 guests
