Page 2 of 3
Re: M1 to V2 Update
Posted: Tue Oct 28, 2014 2:13 pm
by anagurney
Attached is the Error Message I receive and the V1 Rendering and V2 rendering of the same scene. The file path for the materials is: C:/Program Data/Twilight/Materials. I can't send the materials library because it's too big even zipped.
Re: M1 to V2 Update
Posted: Tue Oct 28, 2014 2:17 pm
I'll check the Lampshade_FastFake library and see if there are problems with it. (I assume you downloaded it from this forum?)
Re: M1 to V2 Update
Posted: Tue Oct 28, 2014 2:19 pm
by anagurney
Yes I did.
Re: M1 to V2 Update
Posted: Tue Oct 28, 2014 2:30 pm
It looks like there is a problem with the library. We'll figure out what's going on and get it fixed.
Re: M1 to V2 Update
Posted: Tue Oct 28, 2014 3:53 pm
There is a bug in how the libraries are being searched for. We will fix it in the next release.
In the meantime, you can fix it by going to C:\Program Files(x86)\Twilight Render 2\Legacy. Open the 'Architectural_Twilight' folder and copy all the folders in it, and paste them up one directory, in the Legacy folder. That should work for the converter to find the libraries until we get the fix released.
Thanks for bringing this to our attention.
Re: M1 to V2 Update
Posted: Tue Oct 28, 2014 4:20 pm
by anagurney
OK, thanks.
Re: M1 to V2 Update
Posted: Wed Nov 12, 2014 9:14 pm
by anagurney
I have downloaded your M2 update but, I'm still getting error messages on "unable to load some materials. See the attached message.
Re: M1 to V2 Update
Posted: Thu Nov 13, 2014 2:26 am
Please post the material library that those materials are using.
Re: M1 to V2 Update
Posted: Thu Nov 13, 2014 3:21 pm
by anagurney
Attached is the material library affected. When I pull the materials up on Material Selection under Template Materials, they appear in red. When I click on the the material, it ask me "Do I want to replace the existing deep material with a template".
Re: M1 to V2 Update
Posted: Thu Nov 13, 2014 3:36 pm
Not a screen shot. Please zip and post the actual material library causing the problem.
