V2 Hobby version crashes (on XP)
PRSS
OS: Windows 7
SketchUp: 2020 Pro
Re: V2 Hobby version crashes (on XP)
Post by PRSS » Thu Mar 05, 2015 1:14 am
Well, that is a clear cut answer and settles the matter !
Thank you very much for the reply. I too was waiting for a clear answer.
Best regards
PRSS
Post by Chris » Thu Mar 05, 2015 2:56 am
Sorry for not directly addressing it earlier PRSS. :oops:
dholmes
Post by dholmes » Sat Feb 20, 2016 10:32 pm
PRSS wrote:Hello
Thank you very much for the reply. sorry for my late response.
Probably nobody else other than my own self is still using Windows XP.
That may be the reason that mine was the first report on this. And to be fair, I do not
expect a fix on a free version exclusively for me.
With best regards
PRSS
My Home system That I want to try it out with prior to purchase is an XP 64 Pro and am wanting to test it with the freebie SU 8 First. My work system will come there after and is limited in authorization to folders on that system w/o the company's admins having the go-ahead for any implements I would rather avoid for the time being. after I can get some samples done I can help sway the company in the direction utilizing Twilight especially if a good light exposure tool is produced.
PRSS
OS: Windows 7
SketchUp: 2020 Pro
Post by PRSS » Sun Feb 21, 2016 1:23 am
Hello
It had been clearly said that Windows XP could not be supported - and would not be in future too. So better not to have any false hopes.
The only way for you to test run is to upgrade to a higher version of OS Win7, 8.1 or 10 (a "paper license"/ volume license of Windows allows you to install Win7 also if your computer is not supported with drivers for the latest OS).
In my case I had to purchase a new computer as my old one was not supported with drivers for other than XP.
Best of luck
PRSS
Post by Fletch » Sun Feb 21, 2016 2:38 pm
Chris wrote:As addressed in all your other posts, Twilight Render V2 does not support XP.
Microsoft dropped support of XP, so Twilight can not be expected to continue to support it, sorry.
