Update to the latest version from our webpage at http://www.twilightrender.com/index.php ... ds/upgrade
We are releasing two new features: Section Shapes and Infinite Plane.
Section Shapes allow you to create section cuts in cube, cylinder, and sphere cuts. They can be stretched and rotated just like a regular SketchUp object and, when rendered, will slice into your scene geometry just like a section plane. Or you can invert them and only render what is inside the shape!
Infinite Plane allows you to create a ground plane across the entire view. The infinite plane creates a 10 meter square at the origin of your scene. You can apply any Twilight Render material you want. You can even apply and exactly position a SketchUp texture. Then the material will be applied across the entire view of the scene! And it's not just for floors. Use them to create ceilings, cloud planes, star fields, whatever. You can even rotate them!
Section Shapes and Infinite Plane are available from the Extensions -> Twilight V2 -> Objects menu. They are Twilight Render V2 Professional features only.
We are also releasing the x64 version for OSX, SketchUp 2015. You can find it on our webpage. Please note, SketchUp 2015 is 64 bit only. Make sure you download the 64 bit version of Twilight Render.
Announcing Twilight Render V2.1
- cube.jpg (58 KiB) Viewed 9443 times
- cylinder.jpg (60.41 KiB) Viewed 9443 times
Users browsing this forum: No registered users and 26 guests
