Hello All. Just joined and just downloaded Twilight. I am a former Kerkythea user so I think the transition should be pretty easy and I can already tell that this is 100x easier to use.
I was wondering if anyone here has tried to make a Kalwall material or object. If you are not familiar, Kalwall is a translucent wall panel that is made up of two sheets of fiberglass reinforced sheets (not 'plastic' according to the company) over a grid core. The cavity is also insulated. The lighting effect is pretty amazing. See attached. I have seen forum posts for other renderers and wanted to see if anyone has any ideas here. I figured that I would have to build up the panel just as the actual product is done and try to find a rice paper like translucent effect.
Here is the company's website:
http://www.kalwall.com/
Cheers!
Rudy
Kalwall Material
Kalwall Material
- kalwallscene.jpg (24.07 KiB) Viewed 14373 times
- kalwall-1.jpeg (10.2 KiB) Viewed 14373 times
Re: Kalwall Material
A similar thing was done here: http://twilightrender.com/phpBB3/viewto ... f=13&t=363
use the translucent leaf template and set Opacity in Sketchup to 10 or 20 percent but leave default scattering at 90 percent. this should work when your model is a single face.
Download scene below.
Kalwall material
Template>Translucent>Leaf
Set to 50% and 90% as shown in screenshot.
Scene lighting : Light Emitting material on ceiling - 100w/m2
Scene render settings: Easy 09
Kalwall material
- kalwall-material-settings.jpg (403.26 KiB) Viewed 12397 times
- kalwall-testscene.skp
- (598.55 KiB) Downloaded 638 times
- kalwall-testscene_Scene 1.jpg (162.49 KiB) Viewed 12397 times
