twilight and maxwell
Re: twilight and maxwell
now let us give it 24 hours at 200 degree, and I`ll bet we get some nice rings
the top of the ring (the ring part) is to dark, blackish for some reason...
Cheers,
Adam
Adam
I used Metropolis light transport (BPT) preset. goto presets-->tech--->3)progressive--->04Ecuadorian wrote:Majid has even shown a Twilight render of a glass prism decomposing a ray of white light into its component colors, but I don't know what preset he used.
I remember when I was start using KT ,became so excited , and start a topic to compare Max and KT renders , and a KT team member admired me too, not to do such compares....
in my sight it is a bit hard to do such comarisations... an artistic view could change the result easily... solo (http://www.solosplace.com/) is one of those artists, even when he is working with podium, the result is amazing!!
I think a good render is result of experience (good modeling , texturing, knowing your render engine abilities/limitations ,lighting ...) +a good render engine+an artistic eye and +a good client!!!
you inspired me, and here is my try over a 3dwh tweaked model, HDRI lighting 12 min on my crappy machine
Edited by Frederik: In order to avoid possible loss of images hosted at 3rd party, I've attached the image direct to the TW Forum.
This is the original link: http://www.freeimagehosting.net/image.p ... 3a639e.jpg and
http://www.freeimagehosting.net/image.p ... 67f035.jpg
cheers
- Majid1.jpg (45.79 KiB) Viewed 10878 times
- Majid2.jpg (37.45 KiB) Viewed 10874 times
If you use nk materials and interior+ preset (same as Kerkythea's Metropolis light transport (BPT) preset), then it's really hard to find difference to maxwell in same lighting.
Ok notareal, I did and here is the result after 1 h baking:
This is the original link: http://www.freeimagehosting.net/image.p ... 87ddf5.jpg
- Majid3.jpg (68.81 KiB) Viewed 10871 times
new test.. twilight @ 10+ 18h11m 1335/10000... very good results... more than pleased... as i said. I really like this software
- twilight 1.0.19 10+ render 3135off10000 18h11m.jpg (206.46 KiB) Viewed 10825 times
And you'll be even more please if you use a real camera aperture, even if it's a small aperture like f/8, and select an object to focus on.
and you'll be even more pleased if you increase the number of segments in your curved BEFORE making the model
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 15 guests
