So I inserted some trees into my model from 3D warehouse, and suddenly the scene's a disco.
07 Easy; HDRI sky w/ sun off.
Only lights in the scene are a couple of point lights in the upstairs of the home on the left...
Thoughts?
Disco Trees
Re: Disco Trees
This is likely from the HDR sky. Use a blurry, very low res version of the HDR, or use the Sun/Sky rendering settings.
- sunskysettings.png (16.47 KiB) Viewed 6896 times
Re: Disco Trees
Thanks. Is that the setting I should typically choose when using an HDR?
What's the "science" so to speak, behind it?
So I tried it... using just the medium setting... and it took twice as long and still has most of the spots. :/
Re: Disco Trees
The HDR is likely the problem.
Render with Easy 09, or use a different HDR> did you use the blurry version as I suggested?:rtfm:
The science:
Render Settings Tips
The science:
