Edit and Save History as HDR - V2.x
Posted: Thu Mar 31, 2016 12:21 pm
When you close the Render Dialog in Twilight Render V2 the image will no longer be available, so if you neglected to save the image, it could be lost forever.
If you are using Twilight Render V2 Pro, have no fear - all your renderings in a particular session of SketchUp (these are lost if you close SketchUp) are automatically saved and accessible from the Render History menu item of the Render Dialog.
Double-click any Render History image thumbnail and you will open it in an editing window allowing you to edit the image with tonemapping just as if it were in the original render window.
After editing, save the image as .hdr or other image format as you wish.
