I have downloaded the plugin and everything looks to be installed correctly. I can play with all the tools (template material, scene view, environment, etc) but the second I hit the green power button (render button) I can no longer select anything (in twilight or sketch up). The same is true for the render selection from the drop down extensions menu. Then, I have to force sketch up to quit. I have installed the hobby version v2 64bit for sketch up pro 2016 on mac OS X El Capitan 10.11.6
Please help!
Can't get started rendering
Re: Can't get started rendering
Are you able to see the preview rendering in the material editor, light editor, and environment editor?
Does this happen with even a simple empty scene?
