First try :)
First try :)
Hello Everyone,
I'm totally impressed by Twilight !! I've my own little company & I will by this product in few days for sure
Here You can see my first simple tryouts. With rendering it tooks about 20 minutes...
- 40 passes, HDRi Light Probe enviroment, Interior + preset
- pomarancze.jpg (262.9 KiB) Viewed 11210 times
- Sketchup model looks like this
- pomarancze sketchup.jpg (60.43 KiB) Viewed 11211 times
- SketchUp: 8
Re: First try :)
nice start, the background is perfect...
Cheers, Fred.
http://www.fredericmoro.com
Re: First try :)
... & another on the same table & enviroment.. I think I'm getting started to be addict...
- cukiereczki.jpg (275.28 KiB) Viewed 11157 times
Re: First try :)
Hi Gildzior
Nice render, but a bit bright in some areas!
What render preset did you use?
Re: First try :)
Preset is the same as before (interior +) with light probe HDRi enviroment.
About the sphere... I don't know ... I just downloaded ready table from 3D warehouse & put some default sketchup textures with random shines & refraction in Twilight...
Re: First try :)
likely you applied the "real glass" template to the sphere?
please try watching the video tutorials, it will help you understand everything you need in Twilight in less tha 30mins (for an intermediate-to-experienced SketchUp user)
You need to apply the "Plastic>flat" template to the table, and create a reflection map and bump map for it.
please see the reference section of the user manualfor a little starting guidance on this. the entire Materials section of the manual may be helpful to you?
Re: First try :)
Thanks Fletch
I will look on tutorials for sure
Re: First try :)
Fletch ... Is there any posibility to reset materials ?
I've asigned a mirror to wrong material & now whole room became a one big mirror ?
When i pick this material with pipette twilight turns to library tab & i cannot reset it to default or do nothing ... :/
Re: First try :)
Another 2 tryouts... Floating house
First: Preset Exterior Daytime / 100 passes + HDRi spherical map
Secound : preset High + with Spherical HDRi map
- plywajacy dom 1.jpg (205.52 KiB) Viewed 11052 times
- Exterior Daytime 100 passes
- plywajacy dom 2 - 100passes.jpg (239.56 KiB) Viewed 11052 times
Users browsing this forum: Bing [Bot] and 16 guests
