I like how this came out. I couldn't figure out how to get the exposure of the sky and the scene balanced, so I mashed-up some layers in PS. It uses a sky probe for lighting.
It would be better if I could get the balance right all in one render but I don't know how. If I up the camera exposure to make the scene good, the sky is too bright -- and vice-versa.
Playground
Playground
- pg2 mix.JPG (141.67 KiB) Viewed 5131 times
Re: Playground
What preset are you using? If it's any one from Easy 01 through Easy 08, you can use Tomasz Marek's "Bring My View Back" script to add a background:
http://www.tomaszmarek.eu/sketchup_1.html
...and then make it render exactly as you want:
http://twilightrender.com/phpBB3/viewto ... f=12&t=471
Re: Playground
Easy -08Ecuadorian wrote:What preset are you using?
I'm simply seeking a way to reduce the exposure of the sky probe a little. "Sky Brightness" doesn't see to affect it.
What about darkening the HDR that I use for the sky?
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 9 guests
