material editor floors?
in vs 2.9 for the material editor did the list have an option for floors? i see it has for wood, glass, stone etc. i thought i saw it but then twilight disapperared i had to install it again in su. but not i dont see it
Re: material editor floors?
you need to reactivate it for the pro features, like the floor material template.
Where IS the floor material template?
- FooringTemplate.png (215.59 KiB) Viewed 10564 times
I do not have all of those, reinstall?
If you don't have version 2.5 or later, yeah you should definitely update.
yes, because there are now Lamp Glass templates, and more.
Always upgrade to the latest Twilight v2 - you have nothing to lose.
There seems to be a problem with the license activation which I cannot understand, it was activated previously and seems not to be now, odd. Computers.....
If you are on Windows, certain Windows "updates" will change the Windows Product ID and that will cause your license to no longer work. However, you can just go through the activation process again and reactivate it (should only take about 30 seconds). You will need you Product ID / Product Code. Email us at licensing at twilightrender dot com if you can't find it and we will look it up for you.
Thanks Chris, that is what I did in the end.
