Bedroom scene
Posted: Tue Dec 12, 2017 3:12 pm
It is believed that this model was originally downloaded from the 3DWarehouse. If you know to whom credit should be given, please let us know so that we may give proper credits to the original creator.
NOTE: This zip file contains the scene with Twilight Render lights, HDR, and materials ready to render. Some are original materials never before given away. You may need to go into each material using Twilight to tell it were to find the bump map files. You will need to re-locate the HDR image file in the environment settings.
Please share with us your renderings if you can create something you're proud of.
This example render was done with Easy09 (MLT) with DOF enabled (be careful, as the DOF should still be enabled in the camera for the scene.)
DOF adds to render times.
:>: :>: :>: GET FREE BEDROOM SCENE
See Original WIP thread here.
