Yes, when rendering a pano out by using 6 cams, you MUST use batch render as described in the manual, and be sure that it says "only view" and "REUSE LIGHTING INFORMATION" box is CHECKED. Then, even the lower settings should work. Don't forget to try the render settings named "Animation"- these will also work better for this application/situation.Gaieus wrote:...batch rendering at 07 High+... more accurate rendering will eliminate the seams...
QTVR Twilight
Re: QTVR Twilight
Re: QTVR Twilight
Chris,
Thanks for the tip. It works perfect now.
Re: QTVR Twilight
A little bit "bumping" the topic, here is a panorama I put on the web with the app. Toshiharu posted above (quoted below) - thanks again Toshiharu!
http://www.gaieus.hu/Panoramas/Carmelite/
Unfortunately the flash application decreases the image quality quite considerably but hey, at least it is "publuished"!
Tosiharu Kimura wrote:Hi all
There is Flash VR Player of free.
vista64 and QTVR affinity are not good.
http://flashvr.sakura.ne.jp/index.htm
I made FlashVR from TR.
Since there is panorama(Spherical Projection)write-out in TR, it is possible to make FlashVR.
http://dl.getdropbox.com/u/577270/flash ... v140b.html
Gai...
Re: QTVR Twilight
A cool site for load hdri Image
http://www.openfootage.net/?cat=15
